Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-02-2008, 08:22 PM
bratt bratt is offline
Cool 2000 mustang shows radiator light on cluster
what does it mean when the radiator light is shown on the cluster?
My fluid looks good and my fan is hooked up
I dont see problems
Old 02-03-2008, 12:51 AM
Cool Re: 2000 mustang shows radiator light on cluster
I found out it means my coolant is low
I checked my coolant ands its full all the way up to the overflow
I wonder if its the sensor. I could not find any sensor. I will look harder if anyone knows let me know!
Old 02-03-2008, 05:12 AM
351wStang's Avatar
351wStang 351wStang is offline
Could be that you need to fill the reserve to the full line. I know my fiancee's car will send off lights if the reserve isn't full. Also could be a ad sensor.
1969 Cougar
357w & TKO - 475hp
Old 02-03-2008, 04:50 PM
Well its funny because the reserve is on top of the radiator and the reserve has a radiator cap on it. There is no radiator cap on the radiator.
The reserve is full to the top!
Old 02-04-2008, 12:40 AM
Fordfan5606 Fordfan5606 is offline
If there is a light there is a sensor.....should be located on the overflow tank probably near the bottom. Is it coming on when the car is at operating temp or at all times? may want to check and make sure it isn't running hot if it only comes on after driving. Hope this helps
When everything is said and done, there is always more said than done.
