Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 02-02-2008, 11:44 AM
jjjarceo jjjarceo is offline
1995 Corolla stalls in drive or reverse
Car starts fine, just installed new battery. But when shift to drive or reverse
the car stalled. Any ideas or comments will help. Thank you.
Old 03-08-2008, 10:40 PM
rockwood84 rockwood84 is offline
Re: 1995 Corolla stalls in drive or reverse
when is the last time the pvc valve was changed? if its been a while change it and see if it still stalls .
Old 03-09-2008, 11:45 AM
Just change it very resently.
Old 03-10-2008, 10:23 AM
is the idle speed low at idle?also do you have 1.6 or 1.8?
Old 03-14-2008, 12:10 AM
the idle speed is high when the engine is started cold and gradually
lowers when it gets warm. the engine is 1.8L.
Old 03-14-2008, 01:10 PM
could be the egr valve or the egr vacumn modulator valve.
Old 03-24-2008, 11:32 AM
Finally we fixed the problem by changing the idle speed control
located by the engine side firewall about the center area. This is connected
by one connector with two wires and two air hoses.
