Old 02-01-2008, 08:06 PM
matkns matkns is offline
Smile keyless entry
I know there are many posts concerning this but I am new to this so I am at a loss. I just bought a 99 Chevy blazer for my daughter and it came with 2 remotes that do not work. I tried the batteries, I tried to program them with what I have seen online.....hold down the lock button, turn the key on, off, on, off and the dorrs will lock and unlock. The next step was to hold both the buttons on the remotes.......this doesn't work. I bought another remote thinking the 2 were bad....this one doesn't work. Someone told me to look in the glove box for a code.....AUO and it does have that. Now I am at a loss......can someone out there help?
Old 02-02-2008, 07:23 AM
Keyless Entry receiver
Does anyone know what the cost to fix or how to fix the keyless entry receiver in a 99 blazer?
Old 02-02-2008, 09:19 AM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
Re: Keyless Entry receiver
Do you want to reprogram the reciever?
Old 02-02-2008, 11:32 AM
I don't know if that is the problem but if the reciever needs to be reprogrammed for it to work, I would say yes.
Old 02-02-2008, 11:44 AM
Headnsouth's Avatar
Re: keyless entry
I looked thru the Service info and you'll need a scan tool to diagnose the RKE. Looks like you'll also need it to program it.
Check to see if you have any DTC's at your local autoparts.
Old 02-02-2008, 11:53 AM
Re: keyless entry
you lost me....
What is a RKE and what is the DTC? Where is the receiver located in a blazer?
Old 02-02-2008, 12:09 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: keyless entry
make sure the two remotes will work with that vehicle. call your local chevy dealer with the trucks VIN # to confirm that you have the correct remotes. also when you program the remotes, all doors need to be closed.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 02-02-2008, 12:41 PM
Re: keyless entry
I appreciate this response. The remotes are the correct ones, the doors were closed while reprogramming. With this being said, they still don't work. I am trying now to find out how to locate the receiver in the vehicle and to test it.
Old 02-02-2008, 12:46 PM
ZL1power69's Avatar
GM S-Series Mod
Re: keyless entry
the reciever is under the dash on the drivers side.
Low 11 sec sleeper
My Cardomain
