Old 02-01-2008, 04:35 PM
coachric coachric is offline
2001 GrandAm Clicking Noise Left Front Tire
First time in a forum so thanks in advance for anyone who can help.
I am hearing a clicking noise from the front left tire both in reverse & drive.
I pushed the car in neutral to se if it would click and it did not.
It appears to happen when I am driving straight ahead.
It stops should I turn the steering wheel left or right.
Any help or suggestions are appreciated.
Old 02-01-2008, 06:30 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 2001 GrandAm Clicking Noise Left Front Tire
Welcome to AF .
Sounds like a bearings going bad on that side.
But it could also be the CV joint.
Might have it inspected to varify the troubles.
1999 Grand Am SS 3.4 OHV
Old 02-02-2008, 08:50 AM
Originally Posted by xeroinfinity
Welcome to AF .
Thanks very much, I will do just that. Appreciate your time & input
Old 02-04-2008, 10:38 AM
Another question: I'm being told by mechanics that I'm looking at replacing a hub assembly (hub bearing?) and getting quotes from 325-550, does this sound like the correct price range? I looked online to buy a hub assembly for my car & it was appx 100
Any help would be appreciated
Old 02-04-2008, 04:52 PM
J-Ri's Avatar
J-Ri J-Ri is offline
325 is probably close. $100 is low for the hub, make sure you get a quality part, or you'll be replacing it again. Timken hubs are $130, our discounted price, I'm not sure what you could expect to pay for just one. It takes a couple hours to replace, so the labor rate will affect a lot.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-04-2008, 06:15 PM
I wouldnt buy anything unless it was Timken , they seem to be the best and last longer.
That price is about right on labor and parts for your area out west.
Just ask, who ever does the job, if they are using american parts, the chinese hubs are crap and wont last more then a year.
