Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-01-2008, 02:24 PM
soljuh369 soljuh369 is offline
Unhappy swap from diverter valve to true into the atmosphere, BOV
i have a 99 eclipse gs-t with a stock diverter valve. tomorrow i'm installing a true into the atomosphere suquential BLOW OFF valve. i have heard that not recirculating the air causes problems w/ air/fuel running too rich. what can i do BESIDES buying an aftermarket diverter valve, AND besides reprogramming my car's ECU? or is what i have heard false? i want to install it tomorrow and i've been waiting for this for months putting an SQV on my car... please any help ASAP...
Old 02-01-2008, 02:30 PM
Re: swap from diverter valve to true into the atmosphere, BOV
also, why is it that when i punch the gas on my car in any gear, it hesitates and doesnt accelerate properly unless i push the pedal "not so fast", almost like it's getting too much air and not enough fuel, but there is no check engine light on. it also does it if i go from say, first to fourth and my rpms drop to like 2 grand in that high gear it does it too, what is this
Old 02-01-2008, 02:47 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
The slamming on the gas could be bad spark plugs. Check them for fouling and just replace. Also what kind of plugs are you using? It may also be that as you slowly push the pedal down, the rpms are rising and building boost so it just seems like it's doing more than slamming the pedal down. Check plugs though.
Dumping to atmosphere is not good unless the car has the mods to support it. You will run very rich. The turbo guys will tell you what you need, but this topic has been done over many times. If you do a search you will find the answer. I believe a GM MAF is need so it reads the pressure/air before the BOV, and not after it. Stock, the recirculated air gets read by the car, so it needs to see it if left stock. Someone hit me if I'm wrong.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-01-2008, 04:30 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Dave is right. I would not put that BOV on your car unless you have the stuff to recirculate it. Its only going to make your car run worse. And you should also do a tune up. Make sure your car is running good before trying to mod it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
