Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-01-2008, 12:23 PM
AWILLIAMS64 AWILLIAMS64 is offline
engine codes 171b 172b 174b 175b
i have an 01 passport 4wd 97000 miles. I am getting these codes and it idles rough at stop signs sometimes. It also dies when i start it sometimes. I had the plugs replaced with recommeded plugs from this forum and egr cleaned in past summer. Any bullitens on these codes all together?
Old 02-01-2008, 01:54 PM
mfh_anderson mfh_anderson is offline
Re: engine codes 171b 172b 174b 175b
i bet you have a blown intake manifold gasket. i just changed one that was dying on me while idling and stopped in traffic. i was showing codes for lean, rich, random misfire, and o2 sensors. all fixed by changing intake gasket, then i traded the car.
Old 02-03-2008, 11:36 PM
i hope its not the intake gasket. i know these are o2 sensor codes. I found some at napa for 54.95ea. i dont want to just go replacing parts
Old 02-04-2008, 05:42 AM
you will get o2 sensor codes, because all the air the engine is getting is coming through them. can you hear a sound of air sucking or whistling under the hood.
btw- intake gasket = 39.95 advance auto or auto zone
Old 02-04-2008, 01:42 PM
it is definitely the intake gasket on the drivers side. I got the parts today, along with new antifreeze, oil, filter. I dropped it off to my mechanic today. I didnt even ask a price. I just need it done. Does anyone know about how many hours it takes to do this?
Old 02-04-2008, 02:50 PM
i did mine in about 3 hours or so.
Old 02-04-2008, 09:12 PM
FL 3.2L FL 3.2L is offline
You might provide your mechanic with the correct torque specs if it's not too late. When you pick it up, pop the hood right away and listen for the telltale whistle of a leak.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 02-05-2008, 01:32 AM
i found the torque specs on this site. i think it was changed to 13 from 17 is this correct.
Only info I can give you is that there's a TSB (technical service bulletin) on all 1998 to 2003 Isuzu models equipped with 3.2L or 3.5L engine that revamps the torque specifications for the "gasket intake manifold to cylinder head". Revised torque for both the 3.2L and the 3.5L is 13 lb ft.
Other specs:
Intake Manifold Fasteners: 16 ft. lb.
Common Chamber Fasteners: 18 ft. lb.
Throttle Body Fasteners: 18 ft. lb.
Old 02-06-2008, 12:36 AM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
img replacment is a 1 hr job if the person doing it knows what to do
Old 02-07-2008, 01:09 PM
picked it up today and everything went well. Got the parts at local auto shop for $39.95 and mechanic charged $120 to do the job. no codes and no air leak. Hopefully it stays that way!
