Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 02-01-2008, 09:34 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Fire Supression System: Where are the nozzles? How do I know if it's charged?
I was thinking about adding a fire extinguisher to the rollcage and then remembered the big "fire" switch on my dash and the fact that these cars have a fire supression system. Where are the nozzles? Where does it spray? How do I know if the system is charged and ready to operate?
Old 02-01-2008, 06:20 PM
panoz302 panoz302 is offline
Re: Fire Supression System: Where are the nozzles? How do I know if it's charged?
one nozzel pointing at driver under dash and steering wheel the other in rear of engine compartments directly behind upper intake manifold. The tank does have a guage. It unscrews form the black top and can be recharged. They are supposed to be certified for use.
Old 02-01-2008, 06:51 PM
btwog btwog is offline
I couldnt tell...are they halon or foam? I thought I read the GTS uses a halon system.
Old 02-01-2008, 08:07 PM
Gatorac's Avatar
Gatorac Gatorac is offline
Pull the handle real hard. You should know immediately if there is a charge and where all the nozzles are. If nothing happens, it's empty. Either way you will need a refill.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Old 02-02-2008, 02:31 AM
Cobra4B's Avatar
^ Hahaha... I took it all apart tonight. One nozzle points at your feet and the other goes to the firewall to the back of the motor. There is a gage on it... check yours, mine was empty and the top of the canniser is rusting/peeling.
I took it out and shot off the last few psi for shits and giggles.... need to track down a new bottle.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
