Go Back   Automotive Forums Car Chat > Dodge > SRT4
Old 02-01-2008, 08:17 AM
blksrt4_2005 blksrt4_2005 is offline
head gasket
so im planning on ordering a new head gasket. beacause of the white smoke that shoots out when i go wot and let off.....i heard that i need to buy head studs..is this true???
Old 02-01-2008, 10:19 AM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: head gasket
If you need a new head gasket I would stay oem if I was you. Are you sure you blew the gasket? First do a compression test to verify. You don't necessarily have to upgrade the studs but you can if you would like....so to answer your question...no you don't have to change them unless somehow you bent them.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 02-01-2008, 07:52 PM
Re: head gasket
what else can be causing the white smoke than......???
it only happens when i go wot and let off...
can the spark plugs be causing this
Old 02-02-2008, 01:36 PM
Turbodog97's Avatar
Just a Neon
Re: head gasket
If it's white then it's coolant. It could be a blown seal in the turbo or it could be a busted head gasket. Is your coolant or oil milky at all?
05 Srt4
97 Mx-5
Old 02-02-2008, 07:38 PM
Re: head gasket
no its not
Old 02-03-2008, 11:09 AM
Turbodog97's Avatar
Just a Neon
Re: head gasket
It might be a seal in the turbo just slowly leaking. How many miles do you have?
05 Srt4
97 Mx-5
Old 02-03-2008, 12:02 PM
Re: head gasket
i have 44k miles.....
