Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-01-2008, 01:02 AM
heavyredchevy's Avatar
heavyredchevy heavyredchevy is offline
shutter/vibration
I just bought a 02 Ram 1500 with the 5.9L automatic. When traveling down the freeway at about 65-75mph, in overdrive, with engine load, it shakers and shutters really bad. The guy told me when I bought it that they replaced the engine heads due to a misfire. It seems to run fine at all other speeds. The tranny seems to sift fine. Any Ideas? It has 124k miles
89 Chevy K1500, Extended Cab, Long Bed, 5.7L, 700r4 tranny, 10 bolt rear
Things Done- Flowtech Headers, Heartthrob Deep Tone Dual Exhaust, Airaid TBI Spacer, K&N Intake, 3" Performance Accessories Body Lift, 285 75 R16 Pro Comp A/T Tires, 16" Americain Racing Outlaw 2 Rims, Fabricated Bumper Replacement.
Old 02-04-2008, 03:54 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: shutter/vibration
How long since the last transmission fluid & filter change?
If it's the torque converter clutches slipping, it might be past due for a transmission fluid and filter change and don't fall for the "flush" scam...install a new filter and refill with new fluid.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 02-04-2008, 08:50 PM
I’m sure its never been changed. I pulled the stick when I bought it. The fluid was brown, but it seemed to shift fine. I had planed on changing the filter and fluid but ran out of money. The fluid isn’t cheep. I didn’t know if that would help the problem, but its not going to hurt either.
Old 02-09-2008, 10:27 PM
AF - Advisor
A fluid & filter change fixed my '92 Bravada several years ago. It shuddered going up a grade in overdrive. I had it changed a couple days later and the shuddering has not returned...still got that SUV too.
