Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-31-2008, 10:16 PM
93EclipseGSKo 93EclipseGSKo is offline
Cam Pulley Stuck!!
ok, ive been trying to put a new head gasket on my 4g37. I have the whole engine apart basically. Im trying to get my cam pulley off to get to the head. An the cam pulley is completely stuck. Is it reverse threads? Because i tried both ways for everything i did. First i tried a rubber strap wrench, that snapped. Then i tried a nylon strap wrench, and the pulley kept spinning couldnt get enough grip. Then PB blasted it several times. Nothing came of that. Next i tried heating the bolt up, and of course didnt work. So I then attempted an impact with 340 ft of torque on a 2 hp compressor wich couldnt get it off. Im going to try a bigger compressor, to see if that gives me a little more power. but anyways for the most part this bolt is being stubborn and not coming off. Anyone have any other ideas that may work. And please dont reply to just say do an engine swap and get he 4g63, cuz im not doing it. Thanks.
1993 Eclipse GS BONE STOCK?? Winter Project 07-08
Check out my page on cardomain:
http://www.cardomain.com/ride/2955127
Old 01-31-2008, 10:22 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Cam Pulley Stuck!!
why are you taking the cam pulley off? The threads aren't reversed you shouldn't be having this much trouble with it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-31-2008, 10:32 PM
you have to take the cam pulley off to get to the head. beacuse theres a metal guard between the pulley and the valve cover. And i knw i shudnt be having any trouble with this. but i am. I dont knw what the hell the problem is.
Old 01-31-2008, 11:16 PM
Holset powered 420a
o ok, I dont know what to tell you. Try that impact wrench again with a bigger compressor
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-31-2008, 11:48 PM
MazdaX's Avatar
MazdaX MazdaX is offline
You could always undo the cam's from the head and slide them out of the holes. Did it with my 420A so I know it works. Also you may want to use a torch and heat the bolts up and then hit them fast and hard with a impact gun.
2004 Mazda 6i
1997 Tahoe
Old 02-01-2008, 08:04 AM
Holset powered 420a
I would wait to apply heat after you have the cams from the head. Dont want to melt any seals.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-01-2008, 11:39 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Are you sure you're doing it right? Get a Haynes manual and check it out...
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-04-2008, 03:11 AM
kjewer1 kjewer1 is offline
AF - Advisor
Cam gear bolts are tight, usually around 60-70 ftlbs wih locktite. It takes a good 6 point socket, and an appropriately sized wrench on the cam hex (if you pull the valve cover should should se it). Use pipes and whatever else you need to gain a mechanical advantage and that POS will come off... When I reassemble I usually use 50 ft lbs and medium locktite, much easier to work on the next time.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
