Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-31-2008, 10:28 PM
ALESCI ALESCI is offline
98 Aurora Heater Blower Stopped Working PROBLEM SOLVED
I HAVE A 98 AURORA AND MY HEATER BLOWER STOPPED WORKING TODAY I NEVER HAD A PROBLEM WITH IT UP UNTILL NOW. I DID NOT CHECK ANYTHING UNDER THE BACK SEAT TRIED TAPPING ON BLOWER WITH HAMMER BUT NOTHING !!! PLEASE HELP I CHECKED THE FUSES IN THE FUSE PANEL AND THEY ARE FINE SOMEONE PLEASE HELP ME ? LOSING MY MIND ALSO WHERE DO I FIND THE BLOWER MODULE AND HOW DO I REMOVE IT? IS THERE A WAY TO CHECK AND SEE WHICH ONE IS CAUSING THE PROBLEM BETWEEN THE BLOWER AND THE MODULE ? PLEASE HELP ME SOMEONE ... THANKS. FRANK
Old 02-02-2008, 12:01 AM
Re: 98 Aurora Heater Blower Dont Work
Ok Everyone I Located The Problem I Took Out The Blower Motor And Ran A Test On It Found That The Fan Was Working Fine So Then I Thought It Had To Be The Blower Module I Took It Out And Went To A Place On The West Side Of Cleveland Called Morad"s Parts And I Got One For 35.00 Brought It Home Put Everything Back Together fixed problem Solved... So If Your Heater Does Not Work Change The Motor Module.. Morad's Is Off West 140 Th Street West Side Of Cleveland Ohio If Anyone Else Has This Problem I Hope This Will Help You....
