another '97 jimmy rear wiper ?/only different
My question has to do with the wiper motor itself. I can hear the motor running when I flip the switch, but the arm does not move. The arm does not seem to be broken (ie. I cannot move it freely by hand).My first thought was that the shaft must be broken?But I believe that it is all one piece design. Am I correct? Will I need to replace the entire wiper motor assembly? Has anyone done it? if so any idea on cost?
Re: another '97 jimmy rear wiper ?/only different
I had the same thing on mine, hear motor running but nothing. Remove panels and motor, take apart. There is a round spring washer holding the gears together, comming off and allowing the motor to spin but the gears not engaging. I drilled through the housing and installed a small headed bolt and washers to keep the gears inline.......works just fine instead of spending $ 75 bucks for a re-mbuilt motor.
Good luck. |
