Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-31-2008, 07:40 PM
denneybill denneybill is offline
93 Bonneville Keyless Entry Programming
Would someone PLEASE tell me how to program a wireless remote key fob for a 93 Bonneville SE??? It would be SINCERELY appreciated.
[email protected] (included my email because I don't have a lot of luck navigating on forums )
Old 01-31-2008, 09:54 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 93 Bonneville Keyless Entry Programming
Welcome to AF! Fortunately, your car is quite simple to program. Jump the (ALDL) Assembly Line Diagnostic Link. You will find this connector under the driver side dash, but you will have to look through a square cut out in the panel to see the connector, it is recessed behind that panel, almost directly under the steering column.
Jumper pin A to pin G with a fused jumper (3A)
Doors will lock and unlock
Press the UNLOCK button on the remote
Doors should lock and unlock again
if you have more remotes press their unlock button (up to 4)
remove jumper wire
________|________
[F] [E] [D] [C] [b] [A]
[G] [H] [J] [K] [L] [M]
