Old 01-31-2008, 02:43 PM
gaiusmarius gaiusmarius is offline
Couple of questions 1991 Pontiac Grand Prix LE 3.1
Hi all, glad i found this place! I love my Pontiac, i've had it for several years with no real problems, i've always been very diligent of maintenance on her over the years. But having said that i do have a couple of things that have been ongoing now for a long time. They don't stop the car from performing exceptionaly well, but since i found this place i thought to ask.
1./ There is a "Tapping" sound when i first turn the engine over but this disappears after about 2 minutes.
2./ The Dashboard Temp gauge always goes to redline in the morning after i'am on the highway for a couple of minutes, then goes back to "normal" temp. of 105 very quickly. The max being 125.
Thoughts or shared experiences would be very welcome!
Old 02-02-2008, 08:15 PM
03impala9c1 03impala9c1 is offline
Re: Couple of questions 1991 Pontiac Grand Prix LE 3.1
i would say lifter? for the ticking noise
as for the temp do you have your numbers messed up here because the temp should read normally around 190 to 200 degrees?
***5 WAYS TO KNOW YOUR A REAL MECHANIC***
1. YOU HAVE NO IDEA WHAT THE TERM "ANTI-SIEZE" IS.
2. ADD-A-WRENCH (EXTEND-A-WRENCH) IS YOUR BEST FRIEND
3. YOU KEEP A 3 FOOT PIPE IN YOUR TOOLBOX TO PUT ON THE END OF YOUR BREAKER BAR AT ALL TIMES
4. YOU HATE MECHANIX GLOVES AND USE THEM AS RAGS
5. EACH TIME YOU TAKE A SHOWER YOU SPEND MORE TIME CLEANING GREASE FROM THE SHOWER ITSELF THAN YOU SPENT CLEANING YOURSELF!!
Old 02-04-2008, 04:58 PM
Lifter? is it serious?
The temp gauge only has 2 numbers on it 105 and 125 being the upper limit red zone. Strange because i agree it is normaly for other cars 200 or so. I checked and it is a Canadian built unit, not sure what to make of it.
Old 02-04-2008, 05:07 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
so in other words...the temp gage would be in celcuis
as far as the lifter...on your next oil change, try putting a quart of tranny fluid in the oil, it usually makes the ticking go away. its fairly normal for older cars to do that when you first start them up.
and for the temp gauge problem...try putting a T-stat in it, it may be sticking
**edit** if the T-stat doesnt help, then I'm afraid you might need a headgasket my friend. are you losing any coolant???
Old 02-04-2008, 11:05 PM
Thanks for the help all, well the tapping sound is coming from the top of the engine and your right she is old lol.
No coolant loss whatsoever, the oil is nuce and clean (as always).
The heads look good on inspection, dunno why the temp gage goes up and down when i first start the car, goes away after being on the highway a few minutes. I'll try the t-stat idea, sounds reasonable, pick one up on payday, get back to ya's on it.
Old 02-05-2008, 04:27 AM
FISH96 FISH96 is offline
Dear Gaiusmarius,
Check Your Private Messages For My Reply To Your Query.
Regards,
Fish96
Old 02-05-2008, 03:19 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
the engine in your car is a "zero lash" engine, and no valve adjustment is possible. As they age, they will start to tick, as the lifters and pushrods wear and get a little loose until full oil flow reaches the top end. This is totally normal, and nothing to worry about.
The temp guage going to red line and then back down is an indication of air in the cooling system. It can get in there anytime the system is opened (if you've changed a water pump, thermostat, hose, etc...) and has to be bled out. Since it does this just as the t-stat opens, it sounds like an air bubble, not a bad t-stat. The temp sensor is located in the rear head, between cylinders 3 and 5, and is near the coolant transfer passage. If an air bubble is present, it normally settles in the heater core or rear head after the car is shut off (as these are two of the highest points in the cooling system), and will pass by the temp sensor (causing the guage to peg momentarily) when the t-stat opens.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
