Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-31-2008, 02:06 PM
F!SH 3 F!SH 3 is offline
4G63 Engine
I'm about to buy an engine.. they say its from Japan would it be a direct drop in? need answers quick. thank you.
they say it wont fit due to the fact that the engine bay changed from 95-97 - 98-99 is this true?
96 Eclipse GS Stock
98 Eclipse GST Stock
Old 01-31-2008, 02:16 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 4G63 Engine
The engine bays didn't change at all during those years. At least nothing major. As long as the motor is a 7-bolt it will be fine. Not sure if all the JDM plugs and sensors are all the same but the block and head will be fine.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-31-2008, 04:59 PM
steviek's Avatar
steviek steviek is offline
Re: 4G63 Engine
just cam angle sensor changed after 97 with a few other minor things.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 01-31-2008, 07:52 PM
Re: 4G63 Engine
ok so say i do get the engine... what would have do be done..
96 Eclipse GS Stock
Old 01-31-2008, 08:03 PM
Holset powered 420a
Re: 4G63 Engine
uhh..... Put it in your car...
What year car is the motor from?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-31-2008, 08:59 PM
Re: 4G63 Engine
its for my 98 GST.. its coming from a retailer. said to be a 97..
96 Eclipse GS Stock
Old 01-31-2008, 09:08 PM
Holset powered 420a
Re: 4G63 Engine
Im not sure how much of the motor he is sending you. Basically pull your motor out, when you get the new one switch the stuff over from your old motor to the new one if you need to and then put it back in.
Im assuming your getting the block and head but you may have to swap over the intake mani and maybe some brackets. You will just have to wait till you get it to see what all needs to be done.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-31-2008, 09:14 PM
Re: 4G63 Engine
sounds good.. i have heard you have to switch over the intake mani.. so really nothing major.. i just neeed her to be runnin to get that paper.. buy a beater... and continue to the promiseland..
96 Eclipse GS Stock
