Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 01-31-2008, 12:40 PM
RastusMcNair's Avatar
RastusMcNair RastusMcNair is offline
Rastus McNair
Rear fluid reservior
This may sound dumb but I just bought my 2000 Sil. a couple of weeks ago and can't find my rear window washer fluid reservoir.
Old 01-31-2008, 12:51 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Rear fluid reservior
I don't think there is one. The rear washer is usually serviced by the washer fluid reservoir in the engine compartment with a separate line going all the way to the rear of the van.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 01-31-2008, 01:57 PM
G.A.S. G.A.S. is offline
thats right, and it takes forever for the fluid to get there.
Old 01-31-2008, 02:06 PM
Rastus McNair
I suspected so. After looking the front Res. appears to have two pumps mounted. One high / one low.
The rear sprayer worked when I got the car. The pump in the rear now makes noise but no fluid. I had run low in the front Res., below the high mounted pump, before it stopped. I have since refilled. Hopefully it just takes a long time to re-prime.
Old 01-31-2008, 02:31 PM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
You might be able to fish a small wire in the nozzle to clear it maybe clogged, there is also a connection in the headliner inside the rear door.
You are correct there are two pumps, the upper for the rear and lower for the front.
Old 01-31-2008, 03:25 PM
mhall02 mhall02 is offline
When they get low, the rear pump is a little higher so it won't squirt to the back.
Old 01-31-2008, 04:53 PM
Yes it can take awhile to get the new fluid to the back when you run low. I usually hold the spray lever for the back in short spurts until I get the fluid spraying on the rear window. I'm afraid to hold the lever down to prime the rear pump for too long in fear of burning out the pump.
