Old 01-31-2008, 12:12 PM
dragonfire1179 dragonfire1179 is offline
96 blazer leaking oil
Hi new here I own a 96 blazer with a 4.3 vortec.It seems to be leaking oil somewhere by the pass.side back top of the engine and my oil pressure gauge is now fluctuating at idle but stays steady when revving. any help greatly appreciated.I forgot to say that its not leaking badly,just a slow drip onto the exhaust.
Old 02-03-2008, 12:46 PM
oneav8or oneav8or is offline
Re: 96 blazer leaking oil
Could be a few things, and you'll have to look around the engine bay. A lot of us have had problems with the oil cooler lines weeping after a few years. Doesn't cause a lot of oil drip, but it's annoying. Check that your oil filter is not leaking (tight, but not too tight), oil drain plug not leaking, valve covers not leaking, so on. I would bet its one or all of your oil cooler lines though.
2002 BMW 325ci, 1999 Chevrolet Blazer LS, 2004 Buick Rendezvous , 1991 Kawasaki Ninja ZX-6
Old 02-03-2008, 02:55 PM
old_master's Avatar
Advisor/Moderator
Could also be the oil pressure sending unit or the intake manifold gasket. Clean the engine off with degreaser and watch for the leak.
Old 02-04-2008, 09:42 AM
The oil sending unit is a definite thing im checking into,thats what ive been told before.thanks
Old 02-04-2008, 01:44 PM
herkyhawki herkyhawki is offline
Originally Posted by dragonfire1179
...It seems to be leaking oil somewhere by the pass.side back top of the engine ......
I bet the distributor seal is leaking.
