Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 02-22-2003, 10:27 PM
PilotMojo's Avatar
PilotMojo PilotMojo is offline
Car rides lower on passenger side
So my car is lower on the passenger side, by maybe an inch, but its visible...
Any possibilities... im not to big with cars. But I know enough...
Thanks
1993 Teg GS Automatic (sux)
Old 02-22-2003, 10:56 PM
Duatone Duatone is offline
what do you have for a suspension setup?
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 02-22-2003, 10:57 PM
PilotMojo's Avatar
Its completely stock...
Anything else that needs to be known? rims stock...
Old 02-23-2003, 05:35 PM
hondacivic4drlx's Avatar
hondacivic4drlx hondacivic4drlx is offline
Send a message via AIM to hondacivic4drlx
it might be that your girl needs to loose wieght. j/k
Old 02-23-2003, 06:23 PM
PilotMojo's Avatar
LMAO
Yah i told her that its time to drop a few pounds... i mean, when id spin'm id go in circles... its like the brakes were working on the right side. kinda like canoeing, when you paddle on one side...
lol
Old 02-27-2003, 08:31 PM
emerge's Avatar
emerge emerge is offline
Send a message via AIM to emerge Send a message via Yahoo to emerge
as first i thought it would be your schocks, but that's really weird considering you haven't modified your suspension. all i can say is take it to the shop and get them to fix it?
Stephen Gladney
Original PH Member
EJ8 Civic | AIM: nxzo | www.rtek.org
Old 03-03-2003, 12:07 PM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
i have the same problem on my accord and the 92 integra LS. i haven't checked the integra but the accord has a .4 degrees difference of camber on the left than on the right. might be that your crossbones shifted to the left. i know that's what mine did
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 03-03-2003, 03:25 PM
PilotMojo's Avatar
How do I fix my cross bones??
Thanks
Old 03-03-2003, 05:11 PM
you really can't, unless you replace them. have maaco look at the chassis and have them measure it.
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
Old 03-03-2003, 05:12 PM
btw it costs only 75 to have it checked.
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
Old 04-04-2003, 02:33 PM
94delsolSI 94delsolSI is offline
my cars does the same thing but on the drivers side but i dont weigh very much so... anyway if you replace your springs it should fix it. its probably that one of your springs are starting to compress.
Old 04-14-2003, 07:35 AM
viclaster viclaster is offline
It is probably your shocks. Try to put as pressure on that side if you here any ssshhh sound then it probably is shock leakage. I once had a blown shock on my front passenger side and it was lower than my drivers side.
I Play to Win. I Win to Win.
Old 04-14-2003, 07:55 PM
shocks dont have to do with ride height, so replacing the shock will not help
-~-even satan himself cannot take my sol-~-
Old 04-14-2003, 09:07 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Is this with you in the car or not?
If you are in the car the drop should even out.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 04-16-2003, 09:34 AM
I beg to differ. Blown shocks are capable of giving into pressure. The weight of your car on each side should be the same. Therefore if one shock is blown on one side a slight sagging is possible on that side. Ask a mechanic. He should clear that subject up for you. I'm not tryin to be smart. I've just had some bad experience with blown shocks.
