Old 01-30-2008, 09:05 PM
mulsannemike's Avatar
mulsannemike mulsannemike is offline
Decals...
Seems a popular topic...
I need to create some very small (thin) white stripes (less than 1mm wide) in various shapes. I can create the artwork no problem. And I've printed my own decals in the past at home using the inkject. But the rub now is, how does one print white? Clearly I can't, and while I've thought about hand cutting out of white decal paper, the details will be so painfully small as to be impossible (and thus also too small to mask and paint). Any suggestions as to how to go about this?
Old 01-30-2008, 10:45 PM
CFarias's Avatar
CFarias CFarias is offline
Re: Decals...
Try taping or glueing together two x-acto #11 blades. Then use the two blades, side-by-side, to cut the white decal paper into thin white stripes.
Old 01-30-2008, 10:54 PM
joelwideqvist joelwideqvist is offline
Re: Decals...
To print white on a transparent decal paper you need an ALPS-printer.
/Joel
Old 01-30-2008, 10:57 PM
360spider's Avatar
Re: Decals...
Use BMF to mask the lines and paint it.
Old 01-31-2008, 01:01 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: Decals...
For complex patterns that you can't cut out manually, try printing the boundaries and areas that are supposed to be see-through in the matching body color on a white decal paper.
I assume your decals are very small, and if so, no one would notice if you lay ink on the "in-between" areas.
Hiroaki Fukuda
Old 01-31-2008, 06:42 AM
Re: Decals...
Wow, some really good ideas here. The "inbetween" areas are black so this might just work. And the patterns are wicked small...figure a 4 mm wide octagon with a less than 1 mm wide border...oh fun! I'd tell you what it was for...but I'm ashamed to admit it's not a car....
Old 01-31-2008, 08:15 AM
malscar's Avatar
malscar malscar is offline
Re: Decals...
If the in between areas are black, why don't you print the black pattern on a white decal paper?
Old 01-31-2008, 08:49 AM
cabarbe cabarbe is offline
Re: Decals...
+1.
