Old 01-30-2008, 09:02 PM
sgt.tj sgt.tj is offline
Question Climate Control
I have an 01 Intrigue with the 3.5 engine. The auto climate control stopped working; could not select auto, econo, or off. Also could not set temp; stays at 24 degrees celcius. Stays like that for a while and then can turn off, select econo, and auto but still not able to set temp. The manual portion still works. Any ideas on what is causing this?
Old 01-31-2008, 10:13 AM
dtownfb dtownfb is offline
Re: Climate Control
Does the tempperature remain constant? the reason i ask is many of the automatic controls depend on the outside temperature. You could have a bad temperature sensor which is located on the radiator in front of the car. those are easy to fix on your own.
Old 01-31-2008, 12:16 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: Climate Control
Its part #10248414 Ambient Temperature Sensor for when the dealer parts desk guy cant find it.
Should be about 10-15 bucks, but they may not have them in stock, I had to wait a few days for mine.
But you should only need to replace that, as dtown said, if your external temperature reading is staying the same all the time, or if it is inaccurate.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 02-01-2008, 09:02 PM
Re: Climate Control
It reads the outside temp ok. It is the inside temp that will not adjust. After awhile the off, auto and econo will work but not the temp adjust.
Old 02-01-2008, 10:57 PM
phewop118 phewop118 is offline
Re: Climate Control
That actually sounds like the HVAC controller is going bad. Just look on ebay for the automatic climate control unit. Usually they go for about $25 (new I think they're near $900).
Current Cars:
2001 Oldsmobile Intrigue GLS 154k miles
2005 Chevy Trailblazer EXT LT V8 145k miles
2005 GMC Yukon XL SLT w/Autoride 86k miles
2007 Pontiac Grand Prix GT 77k miles
2007 Cadillac DTS Lux II 47k miles
In Limbo:
2003 Oldsmobile Aurora 4.0 - got side swiped while parked, waiting on insurance decision
Recent Past:
2007 Hummer H3 5-speed Lease was over 7/17/10
