Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-30-2008, 04:12 PM
2003blackgt 2003blackgt is offline
How to bypass factory amp on 03 eclipse gt
jus wonderin if anyone could help. how to bypass my factory amp because i have an amp that i took out of my old car but i cant get it to work. please can anyone help me?
Old 01-30-2008, 07:13 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: How to bypass factory amp on 03 eclipse gt
Well, what exactly are you wanting to run off the amp you put in...just a sub, or do you want your stock amp to still run your mids and then the other amp to run a sub...or are you wanting your new amp to only run your stock speakers, or are you gonna use 2 amps (one for sub and one for stockers). How I did mine was before I installed my aftermarket speakers and was just running a sub and new head unit I was able to run the sub out RCA to the sub amp and the other speakers I was simply able to hook up to the new HU from the stock amp. If you want to bypass the amp entirely then just dont hook it up to the HU (I took mine out when I put in my new touch screen). If I remember correctly I had no problem at all trying to figure out what needed to be done...if anyone else has any other ideas let him have it.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 01-31-2008, 12:27 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
the amp is located under the passenger seat. pull the wires you don't want out, and put them in something else... ta da!
but seriously, knowing more of what you are doing is going to help you. the more clear your question is the more clear we can make an answer for you.
Don't act like you don't love it.
503/2000
Old 02-02-2008, 06:06 PM
um more clear im jus gunna run one sub from the amp that im gunna put in. ive unhooked the wires outta the factory amp and then hooked up my new amp and nothin came on. ????? hopefully thats enough for u guys to help thanks
Old 02-05-2008, 01:11 AM
rodbls's Avatar
well, not sure if you know this or not, but is the new amp a mono block amp, or is it a 4 channel. If it's a mono amp them of course nothing will come out because you factory speakers will not be powered by anything...also, if you are running a stock head unit I am not sure there is a sub out (but if you have the infinity system you will have a center speaker, so just run that wire from the head unit to the new amp and reconnect the other wires to your factory amp and that should work.)
Old 02-05-2008, 07:41 PM
jay510's Avatar
jay510 jay510 is offline
i know how....i did it not to long ago....
you got to cutt wall wires connecting to the gay ass stock amp.....then find your car audio wiring colors..(brown / red, red/white etc...) they can be found on google.....those wires are your speaker wires....its about 12 wires...now once u find that then connect those wires to your deck wires..and you set to go......installation is about 1-2 hours if you dont get tooo bored....
i think i still have pics of it being installed ....pm me if you need futher info
2003 eclipse GT spyder v6
MoDs:
evo catback exhaust
K&N Cold Air Intake
20'' crome & black rims
Tein lowering springs 3''
Alumn Radiator...in progress, to lazy to do it.....
projector headlight black
removed rear wing
window tint black
x2 12' audioban subs
more to come......
supercharger coming soon after my performance headers
