Old 01-30-2008, 04:41 PM
scot399 scot399 is offline
95 1/2 ton, 305ci, high idle
Idles at 1500 rpm, slowly grew worse. Engine temp does not affect the idle.
Have changed temp sensor, map sensor, idle air control valve, and throttle position sensor. Have checked and double checked for vacuum leaks. PCV valve is also not faulty. No mechanical binding in throttle cable. Runs great otherwise.
Have run out of ideas.
Old 01-30-2008, 05:13 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 1/2 ton, 305ci, high idle
If TBI injection
Replace TB to intake base gasket.
MT
