Old 01-30-2008, 03:06 PM
mattadamsnet mattadamsnet is offline
It sounds like someone rear-ends me and shakes the truck.
after i travel at highway speeds for 30 or more mins. i'll stop at a red light and as soon as i take off from fist to second gears a loud boom that shakes the truck comes from the rear end. it'll continue to do that untill it cools down, and it wont do it untill run it at hwy speeds for a while.
i got a 99 chev tahoe, just bought it. it's in great condition otherwise, 118k
Old 01-30-2008, 05:08 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: It sounds like someone rear-ends me and shakes the truck.
Check trans, transfer case (if applicable), and differential(s). Also make sure there's nothing loose.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-02-2008, 11:19 AM
rockwood84 rockwood84 is offline
is there gear oil in the rear end? the gear oil should be right at the fill hole. sounds like the gears and bearings are getting hot after running highway speeds.
Old 02-03-2008, 08:26 AM
j cAT j cAT is offline
this i believe is caused by the wrong/contaminated rear diff fluid. replace fluid remove/clean cover and magnet. inspect for metal shavings buy tube of silicone gasket clean sufaces before applying sealant.make sure you use the correct diff fluid use vin to verify..............should take 21/2 quarts............
Old 04-05-2008, 09:38 PM
bubba99 bubba99 is offline
This is the same sensation I get when the differential lock-up mechanism engages. It should only engage when one rear wheel is spinning faster than the other. This is Chevy's answer to coming up with something cheaper than the posi-trac rear end. You can remove the cover and examine the kick-in device. Good luck.
Old 04-10-2008, 07:46 PM
MyTOY's Avatar
MyTOY MyTOY is offline
research trouble code P1870. To get by until I got my trans rebuilt, I would turn the truck off and on again and it would reset until next stop.
03 WRX
