Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-30-2008, 10:46 AM
blueyedchik79 blueyedchik79 is offline
Red face stuck gearbox
In my manual 5 speed 2000 Eclipse GT the clutch feels spongy and the gearbox is really sticky. This morning I thought I wasn't going to be able to drive it because it wouldn't change gears at all. Finally I slammed my foot down on the clutch and it finally went into first gear. After that while driving it sounded like it was going to stall and every time i changed gears it sounded like it was scraping, like the clutch couldn't go down far enough to release the gears. What do I dooo?
KP
Old 01-30-2008, 07:17 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: stuck gearbox
Well...easy steps first. Make sure you have tranny fluid, make sure your clutch line is bled with plenty of clean fluid and make sure your connections from the clutch pedal to the gear box are clean and lubed. After that it could be a number of things. Your synchros might be shot (SOL on that one), your clutch might be blown (again, not a cheap fix). If it was real cold out than the clutch will feel real shitty and the shift lever will be real gummy until everything gets to temp...if that isnt the case, and the first few things I said were good then it's probably one of the latter, or something else. Take it to a mechanic and have them look at it.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 01-31-2008, 02:33 PM
Re: stuck gearbox
Thanks. It was really cold outside, and I figured I'd wait and let it warm up for like 15 minutes and try and loosen everything up. I think it'll be fine, but I'll take it in anyway.
