Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-30-2008, 08:53 AM
6669charger 6669charger is offline
98 trans am electrical
I have a 98 trans am that I have had to replace both headlight motors,both window motors.and I have one bright headlight & three dim ones I suspect its a ground but not sure where to start?
Old 01-30-2008, 04:54 PM
FTA9597 FTA9597 is offline
Send a message via AIM to FTA9597
Lightbulb Re: 98 trans am electrical
I believe that everything is solid state now for the 98 and up.
I have a wiring diagram for that year if it helps. ill fax it if ya send me a number.
but from looking at it with the problem you described, I' can't tell the issue.
F bodys are very goofy when if comes to the chassis wiring, especially the grounds.
Are your tail laight fine?
signals?
voltage, appropriate amperage supplied to area?
Old 01-31-2008, 06:29 AM
If you could fax wiring diagram to 765-474-7114 I would appreciate it. The left taillight is dim also but everything else is fine.
Old 10-07-2009, 05:05 PM
dcwfn dcwfn is offline
Question Re: 98 trans am electrical
I/we just "adopted" a 1998 Trans Am. We'll be doing something asap with it's remote start/entry system because the remote we got with it's keys was/is a POS. We need to know asap how to at a minimum disarm the security system until we decide which way to go on the remote. Is there a specific fuse we can remove that won't mess up any other functions on the car?
