Old 01-30-2008, 08:20 AM
cruiser69 cruiser69 is offline
Upper Intake Manifold
I have a 2002 GT 3.8 with 61K on the engine. I had the upper and lower intake gaskets replaced about 10,000 miles ago. Now I am told that the upper is leaking again already. Could this be because they never replaced the actual intake and just the gaskets.
Old 01-30-2008, 10:42 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Upper Intake Manifold
Yes, it is not as common on the 00-up's for the UIM to fail (it's usually just the gasket) but if let go too long, the coolant leak can erode the passages in the UIM. I personally wouldn't take the risk on reusing the OEM plenum with the aftermarket replacements being so cheap these days.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-30-2008, 11:12 AM
Is replacing the plenum and gasket a hard job. I would like to repair it myself instead if paying someone to do it again.
Old 01-31-2008, 07:57 AM
GTP Dad GTP Dad is offline
Pontiac Guy
It is not hard to replace the gaskets for the UIM but it does take time. Check the maintenance section as there should be something there to instruct you on the proper procedure. However, I would still invest in a manual to make absolutely certain that you are doing the job correctly. Good Luck!
