Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-29-2008, 10:20 PM
mcc88 mcc88 is offline
Angry '88 5.0 horrible rev problem
I started getting a idle and rev problem awhile back. It would start fine, then it would rev up to sometimes 2700rpm and sometimes 4000rpm, and then it idles down and sometimes dies. Sometimes it won't idle down by itself. I would kick the throttle and it would go down, but then it would rev up right away again, and then back down, then up, then down, and so on... After it started happening, i smelt fuel! The pressure fuel line off of the gas tank was resting on my tailpipe, and melted a hole in it, so it was loosing fuel pressure. So I put new lines on from pump (tank) to filter and hard line. That solved the problem for approximately 4 hours! Now it's doing the same thing all over again!! Except this time, the lines seem fine. No kinks or holes, and are routed nicer than before (away from tailpipe). Any ideas?
Old 01-30-2008, 09:00 AM
stevenhess stevenhess is offline
Re: '88 5.0 horrible rev problem
what size fuel pressure regulater are you using?
94 Mustang GT 5.0L converted to a edelbrock intake manifold and edelbrock carburater, o/r H pipe with flowmaster 40's, 17 in cobra r wheels, msd package including coil and distributer, ford racing vavle covers, steeda short throw shifter, king cobra clutch, T5 3:55 geared transmission, and a non-slip poze rear end!
Old 01-30-2008, 10:55 AM
351wStang's Avatar
351wStang 351wStang is offline
Tps
1969 Cougar
357w & TKO - 475hp
Old 01-31-2008, 10:44 AM
Stock regulator? Not sure what mod's the car has or if has any, but before these problems, the car ran very strong. It does have x-pipe following with dual flowmaster back. No catilitic converters, but has both O2 sensors still. I had it for a year before the car started doing this. ???????? Could the fuel line have a slight blockage somewhere?
Old 01-31-2008, 10:45 AM
Originally Posted by 351wStang
Tps
Thats a possibility. If not??????
Old 01-31-2008, 05:05 PM
Turbokid15's Avatar
Turbokid15 Turbokid15 is offline
Tps
Or Idle Air Contro valve.
The truck
07 F-350 CC Dually Stroked
