Old 01-29-2008, 10:01 PM
jkoecke2002 jkoecke2002 is offline
cold air
I have a 94 s-10. my question is: what would cause my heater to blow cold air after it has been blowing hot air? I am going to change the thermostat and gasket, is there anything else that would cause this?
Old 01-29-2008, 10:32 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: cold air
What is the engine temperature? Is it running cold? If the engine is running cold, chances are its your thermostat. If your engine is warming up to proper temperature, yet your cold, you should be looking at other sources.
Old 01-30-2008, 01:10 PM
Re: cold air
it is running at normal driving temperatures. what else could it be?
Old 02-02-2008, 04:18 PM
Re: cold air
i have changed the thermostat, will post again if that did not solve my problem.
Old 02-02-2008, 09:18 PM
old_master's Avatar
Advisor/Moderator
Re: cold air
Check coolant level, make sure it's full. After the engine is at operating temperature, check both heater hoses where they go into the heater core. They should both be very warm, almost too hot to hold with bare hands. If one is noticeably cooler, the heater core is restricted and needs flushing or replacement.
