Old 01-29-2008, 09:36 PM
Jeepjones85 Jeepjones85 is offline
Unhappy 03 driver side power door lock and window wont work
I have a 03 gmc sierra ext cab
My driver side control panel on the door will not
work, the PW, lock and mirror buttons will
not do any thing. I can push the key fob buttons
and the only thing it does is unlock the passengers
door. I checked all the fuses and relays that i
could find. I dont know what else to do...
Old 01-30-2008, 10:24 AM
j cAT j cAT is offline
Re: 03 driver side power door lock and window wont work
remove door panel check that connector is properly seated into the control switch assy. was this door replaced /repaired by body shop?
Old 01-30-2008, 04:26 PM
Red face Re: 03 driver side power door lock and window wont work
Thanks for the help every thing seem to be pluged in
so i took every thing apart and tested all the
connectors and i do have power to the chip
board i called the dealer and he said that it was
a common thing for the boards to go out. He also
said if you have power on the big orange wire coming
to the board but nothing works its bad. They want 168.00
for the switch assembly. is there a cheaper place to get one?
I also looked the board over good and didn't notice any burnt
spots to be fixed...
Old 01-30-2008, 04:51 PM
777stickman 777stickman is offline
http://www.gmpartsdirect.com/
Their prices are good but sometimes with the S&H the cost is over what the dealer is asking. Be good if you had the P/N before you go to the site.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-30-2008, 10:06 PM
rfurton rfurton is offline
Lightbulb Re: 03 driver side power door lock and window wont work
Hope you have a friend that can buy from a GM dealer at wholesale prices. If not try a local Salvage(junk) Yard. If they have a damaged door they will sell the inner parts. Also try ebay. Good luck.
Old 01-31-2008, 11:07 AM
waitingforcolumbus waitingforcolumbus is offline
I use mine so seldom the switches corrode. It's happened a half dozen times. If I operate the switch a couple of dozen times it starts working again. Try that with the key turned on. Maybe some of that switch cleaner spray before you spend the big dollars.
