Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-29-2008, 08:13 PM
BOX88 BOX88 is offline
Window trim
Searched and nothing came up
If you look you can see the cracks in the rubber, well when ever it rains really hard water gets in there and right now my door is full of water in the inside. Does anyone know where I can get this stuff from? For a four door caprice. I would like new ones all around.
Old 01-29-2008, 09:26 PM
Blue Bowtie's Avatar
Registered Offender
Re: Window trim
Clean out the drain slots on the bottoms of the doors (the oval openings).
Check this place for seals:
www.metrommp.com
Old 01-29-2008, 09:46 PM
mike561 mike561 is offline
Re: Window trim
Mine are still rubbery, they might have been replaced, wish i knew where and how though for future reference
2006 Chevy Cobalt LS
Old 01-29-2008, 11:29 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Window trim
They bolt to the inside of the doors, you have to remove the window glass to access them. It's not too difficult. Remove the two bolts that hold the glass on to the regulator, and give a slight pull to the glass to derail the window guide. It wouldn't be a bad time to replace those window guides while you're in there; they're cheap from the dealership (I paid $4.00 for both front windows) and if the old ones break, the window 'drops' to one side. The glass pulls out of the door relatively easily.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-30-2008, 12:06 AM
Re: Window trim
www.metrommp.com
I didnt see them on there.
Old 01-30-2008, 07:03 AM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Re: Window trim
Yeah i've been in need of new trim for a while now. Its so dried out that on the drivers side theres just a big gap where the rubber used to be. And on the back windows they move at a snails pace and i htink the rubber is restricting them. "They also could use a good oiling." Too bad my doors are so rotted out at the bottom that theres nothing to get the doors clogged up.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 01-30-2008, 10:54 AM
j cAT j cAT is offline
Re: Window trim
If you look you can see the cracks in the rubber, well when ever it rains really hard water gets in there and right now my door is full of water in the inside. Does anyone know where I can get this stuff from? For a four door caprice. I would like new ones all around.[/quote]
go to 1a auto parts they have a good selection, of alot of rubber door parts. i believe your part is called a window sweep. this company is located in massachusetts and there is a tel. # for questions . i got my door window regulator very fast shipping.
Old 01-30-2008, 06:19 PM
Re: Window trim
I found the front door ones, but now I need the back door. Cant find them seem to find them
I did find this though. http://www.topsdown.com/Window-sweep...ces--p931.html
You guys think this will work?
So I need to remove the door panels and the window to install these?
Old 01-30-2008, 07:42 PM
silicon212's Avatar
Confoundingly Lucid
Re: Window trim
I don't think it will come close to working.
Old 01-30-2008, 09:26 PM
Re: Window trim
never seen those before, they wipe the glass which is cool though, i hate when the side windows get fogged up, especially here in humid florida on an early soggy morning
Old 01-30-2008, 11:54 PM
beat88ls's Avatar
beat88ls beat88ls is offline
Re: Window trim
j cAT:
wow they are 15 minutes from my house
1997 Jeep Grand Cherokee Laredo 4.0L
2004 Jeep Grand Cherokee Laredo 4.0L
1983 Caprice Classic 5.0L
Old 01-31-2008, 07:46 PM
Re: Window trim
Okay well maybe modifying the front ones a lil to go on the back maybe?
I know they are pretty much straight then at the end there is the lil curve. Maybe just cut the end off and adjust it to fit.
