Old 01-29-2008, 06:31 PM
kahjdh's Avatar
kahjdh kahjdh is offline
01' Z71 Suspension
Time to do some work on my truck now that I have some free time comming up.
First: Ball Joints
Anybody done these yet? I have never done them on a torsion bar set up but I plan on doing all 4.
Second: Creaking in rear
Everytime I go and stop there is a clunk-clunk and I cant feel the back of the truck move either up or down depending on if im going or stopping. I have lifted it up and nothing is loose or noticeable. It is driving me nuts, need some help here.
Three: 100kmi maitenance
I plan on doing plugs/wires, oil change and trans filter. What are the best plugs (No Bosch, they foul up too quick) and who makes a good trans filter? Do these trucks have reusable pan gaskets?
Any thing else to tach would be great. Any opinions on that creak are needed because im stumped.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 01-30-2008, 02:30 AM
bigbadram51 bigbadram51 is offline
Re: 01' Z71 Suspension
I can only really help you with a couple... Non serviceable upper ball joints on half-tons... the whole UCA needs replacing. As for the creaking....maybe worn u-joint.
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 01-30-2008, 10:59 AM
jtc001 jtc001 is offline
In terms of the upper ball joints, Chevy does not sell them separate. However, both Autozone and Advance Auto Parts do carry a listing for the upper ball joint.
Can't help you with the undercarriage noise.
I just did a tune up - I have the 5.3 eight. I found that a spark pug wrency with a universal along with extensions of various lengths came in handy. Not too bad of a job. I put in the current Delco plugs.
I'll be interested in the tranny filter change - mine is due.
Good luck.
Old 01-30-2008, 02:06 PM
j cAT j cAT is offline
First: Ball Joints
On your clunk. my vehicle at 30,000mi made what i call ka thump noise when starting from stop at light. the colder the temp the longer it would do it. under warrantee i brought to dealer [i don't like dealers] and he tells me this story of how it's the trac II transfercase fluid loosing it's lubricity. and that after they replace fluid for free! in 10mi the noise will be gone. well the noise did go but what i found was this fluid must be replaced every 30-40,000 on internet forum searchs as if you do not transfer case will die........I used a napa transmission filter as i have the deep pan and the filter cost 23.oo. the markings and plastic mold is the same exact as the original that i took out. the dealer wanted 57.oo. synthetic trans fluid is best i found in cold weather faster shifting ......got rubber gasket from napa used it 3x times must torque to 7ftlbs max its rubber no need to over tighten.never a leak
Old 02-05-2008, 06:31 PM
kahjdh's Avatar
Update:
The clunking was the yoke from the front of the driveshaft binding with the tailshaft of the transfer case. Little bit of grease and all is good now. Replaced the rear U-joint because the drivesaft was off and it was easy, didnt do the front b/c i was pressed for time.
Current Cars:
Past Cars:
Old 02-06-2008, 05:40 PM
Update:
ha ha ha been there and back pal ! it works only for a very short time. your gonna learn the cheap hard way............have a cheap day........
Old 02-06-2008, 06:07 PM
Evansamms Evansamms is offline
I dunno, I did the same thing with my Ext Cab Long box (of course my slip yoke is in the middle, with a hanger bearing), but I greased it with Red-N-Tacky hard grease, about 7 months and 15,000 kms ago. Hasnt come back yet.
Old 02-06-2008, 06:11 PM
kahjdh's Avatar
The cheap hard way? How else do I fix it?
Current Cars:
Past Cars:
