fuel rail and injectors
hey im going to be doing my obd1 swap here in a week or so and the guys at rywire told me to just use the obd0 injectors and resistor box so my question is will the obd0 injectors fit in the y8 fuel rail. does the y8 fuel rail flow any better than the 4th gen si rail. does the flow diffrence if any make any real diffrence. also has anybody out there mad an adapter plate for a z6 dizzy to go on a y8 head going to have to make one and was wondering if anybody had some tips on fabrication, havent been able to look at my car cause its in storage so i dont have a visual idea of what im going to have to make. may be overthinking this. thanks Paul
Edit: also where is the fast idle valve located on the 4th gen? Last edited by pbrizzle86; 01-29-2008 at 06:47 PM. |
Re: fuel rail and injectors
I can't answer all of your questions, because I honestly don't know all that much about 4th gens. But through the research I've done, the Y8 fuel rails is supposed to flow better than the '92-'95 Civic fuel rails; so that should be some kind of indication. I highly doubt it would make any real difference though. They also have different mounting points, so I'm assuming that the 4th gen & Y8 fuel rails aren't intrerchangable (again, just assuming). As for the distributor, the Z6 one doesn't fit right, you can use a D15B7 ('92-'95 DX/LX) distributor and it will work fine (I believe the '92-'95 CX one will work too, but I'm not positive on that).
also i was wondering if anybody has tried to swap the internals from an obd1 dizzy into an obd0 frame/ housing just wondering if this could be done. thanks paul
Unless im seriously mistaken, the FITV is only on the b series engines, and select d series.
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
i thought it was the silver thing under the throttle body with two coolant lines running to it, but would like to know for sure. cause when i put my car away for the winter the idle would rev between 800 and 3000 rpm. i put the smoke machine on it at school and didnt find any vaccum leaks. i just did a head swap so i know all the gaskets are good. and yes it was doing it before i did the head swap. ive cleaned the IAC and even tried another one i had. checked the voltage at the iac and it was in spec so that lead me to the internet and the fast idle valve.
Yeah thats a fitv then...guess I was wrong.
sweet i hope this fixes my problem im going to my moms to look at it tonight. i must say having a loud ass exhaust and a surging motor makes you dread coming to a stop light. thanks Paul
i took the fast idle valve apart and the part were the piston rests against was really loose tightened it back down and my car idles again very happy and it was like a ten min thing.
Sweet man! Glad to hear something got fixed.seems lately people are coming up with more and more obscure crap that they cant fix for months. *crosses fingers*
ha thats great. i know i was getting worried about doing this obd1 swap and still having it idle like crap afterwards, because all my sensors and iac were all working properly and were all clean too. its not very often we get thrown a fix that takes 5 mins to do and actually takes care of the problem.
