Old 01-29-2008, 04:39 PM
joedoer joedoer is offline
broken bolt....ideas?...
Hey all...
I have a 93 voyager...3.0..went to install a new t-stat..
one of the bolts turned a hair then the head snapped off..
the other one came out rough ..it was crapped up.
My question is...what can I do to extract the other bolt without having to replace the intake....
any thoughts/ideas would be greatly appreciated...
Old 01-29-2008, 05:28 PM
Cntrysthbst Cntrysthbst is offline
Send a message via Yahoo to Cntrysthbst
Re: broken bolt....ideas?...
This explains better than I can,
http://www.asashop.org/autoinc/may2003/techtotech.htm
and,
http://www.dimebank.com/tech/BrokenBolt.html
Here are what some look like,
http://www.brandsplace.com/tool-hand...xtractors.html
Old 01-29-2008, 09:14 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Hey, I like those links. Thanks
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 01-30-2008, 06:54 AM
webbch webbch is offline
If the head snapped off, then you've been able to remove the T-stat housing, right? If that's the case, the the remaining portion of the bolt is sticking up quite a ways out of the manifold and has easy access, right? If so, I'd go to work on it with a pair of vice grips. If that didn't pan out, I'd weld a new bolt onto it, and use the hex of the new bolt to twist it out. That's been my most succesful method to date. Welding a washer and nut on as suggested in one of the links is a good suggestion too.
2003 Honda Odyssey EXL (3.5L)
2002 Volvo V70 X/C
1990 Chevy Silverado K2500 (5.7L TBI)
