Old 01-29-2008, 03:43 PM
readyforfunnow readyforfunnow is offline
99 Lesabre drivers side high beam won't work
99 Lesabre, V6 Custom with all the bells and whistles. The drivers side high beam head light bulb will not go on when I have selected high beams. The bulb is not the problem, because I bought a new one and tested the situation by putting in the bulb from the passenger side into the driver side socket. All this means is that I am not getting current to the drivers side high beam bulb. I don't know if I have a short in either the black or green wire leading to the bulb or some other problem like a relay switch problem somewhere.
I would like to know what tests I can make or if someone knows what the problem is and could offer a solution (as cheap as possible). Thanks so much. John
