Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 01-29-2008, 11:56 AM
MyOwnDemise MyOwnDemise is offline
Send a message via AIM to MyOwnDemise
1994 Dakota 318 V8 Runs like crap
I just got a 92 Dakota V8 with 130k on it. It has a hard time starting but when it starts it idles fine. When I put it into drive I can creep it foreward or backwards but when I step on the gas its like it wants to die. I can go 20mph tops with this thing. Its a gorgeous truck and I dont want to get rid of it. I changed the inline fuel filter on it with no success. Could it be the fuel pump? The wires look new, but I havent pulled them off yet and checked the plugs. Any help would be appreciated
FYI - Not a newb, I have been reading this site for close to 3 years I just rarely have had a need to post!
You cannot kill what you did not create - Slipknot
Old 01-29-2008, 09:33 PM
troy1 troy1 is offline
AF -Advisor
Re: 1994 Dakota 318 V8 Runs like crap
Go get it checked for codes.
Old 01-29-2008, 11:04 PM
No codes - mechanic pal of mine brought his tester to my house because the truck isnt on the road. Changing out fuel pump next week. Before I do that, is there a difference between the 3.9 and the 5.2 fuel pump? The gas tanks looked identical.
Old 01-30-2008, 10:35 AM
Benzman Benzman is offline
Could be the fuel pump, or the sock on the fuel pump. If there is water in the tank, the sock will restrict almost immediately. Changing the pump will only temporarily fix the problem in that case.
Could also be old fuel in the tank, if it has been sitting a while.
In either of those cases, I would empty the tank, refil it with fresh fuel.
Could be a clogged Catylitic converter or muffler.
Could also be low cylinder compression, not a good situation.
Does the engine increase in RPM smoothly, if it is left in neutral (no engine load)?
Old 01-30-2008, 01:29 PM
The idle is smooth no matter what gear Im in. I think when I drop the tank to change the pump Ill empty it out and just put fresh gas in it. I will post pics of the work I do as things progress. I will also post pics of the truck today or tomorrow
Old 01-30-2008, 06:02 PM
Update as of 7pm - I went to the salvage yard and ended up talking to the guys there. I tried the easiest inexpensive thing that I overlooked (Because my old 93 had a similar problem) and put drygas in it. AStarted up on the second crank and runs like a top. I love my DODGE!!
Old 01-31-2008, 08:40 AM
Is "drygas" a water remover for fuel, similar to Heat?
If so, then it was water in the tank, clogging the filter bag on the fuel pump.
Just put more of the "drygas" in the next 2 or 3 times that you fill the tank.
Old 01-31-2008, 09:39 PM
Yes it is. It still hesitates somewhat but the cold of night and the sun in the day makes a difference I think. Also I was just told that it sat for 3 months, so just running the old gas out will take a little bit of time. So far so good with it - but I have no heat!!! My blower motor is shot, any advice there?
Old 01-31-2008, 10:15 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Condensation can happen in a nearly empty fuel tank when the temperature drops sharply (day to night). WTG in finding the ultimate cheap solution!
As far as the blower, check the fuses first, then yank it out and see if it spins freely by hand. If not, the bearings have seized or are shot. You MIGHT be able to disassemble the motor or just squirt some lube into the ends where the bearings are...a stopgap fix at best. A continuity check will test the coil around the motor...no continuity means bad coil and time for a new blower.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
