Old 01-29-2008, 11:09 AM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
lossing coolant? coolant res.
do our cars have coolant lines to the turbos or just oil. im sure its just oil but ive heard ppl had coolant lines aswell as oil lines to the turbos? my issue is my coolant light comes on and the resivour gets low\empty but i fill it back up and then a week later its low again (coolant light comes back on). its been cold so i was wondering if that has anything to do with it, and ik im not burning it threw the motor bc my exhaust isnt smoking or anything, im confused... or my resivour might have a small crack or something idk, any ideas? i dont notice any leaks anywhere when i look and no puddles under car after its parked. i put a steel braided hose on my coolant pipe, i was thinking it might have been loose but i tightened it up, and since it hasnt been as cold as it has been when this was occuring it hasnt happed again.(also when the light would come on, it would be on then go off then come back on while i was driving then would stay on after a while
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 01-29-2008, 12:17 PM
DCIV's Avatar
DCIV DCIV is offline
Re: lossing coolant? coolant res.
yes our turbos have water going to them. Just follow the sweet smell of antifrezze till you figure it out.
Coop
Old 01-29-2008, 12:37 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
If it isn't leaking out then it's being boiled into steam somehow. Either by leaking onto something hot or by getting into the combustion chamber. You wouldn't necessarily see steam.
Old 03-01-2008, 10:16 PM
I havent found the problem yet but its to cold out to get into detail but ive changed the thermostat thinking it was bad and thats y i was loosing coolant, but its still losing coolant, what would cause it to loose a full res. tank of coolant in like a day or 2? after i did the thermostat i filled the overflow to the top and with in the next 2 days my light was on again, im stumpeed i dont think it burning threw the turbos would cause it to lose that much that fast, what could be the problem?
Old 03-01-2008, 11:26 PM
AutostradaVR4 AutostradaVR4 is offline
i would do a compression test, just to be safe. The only way to lose coolant that fast if it's not in a puddle on the ground is out of the exhaust.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 03-02-2008, 06:25 PM
what could it be if it was on the ground in a puddle? my dad says he sees it on the ground sometimes rite where my overflow would be.
Old 03-02-2008, 10:51 PM
Polygon's Avatar
The Red Baron
First thing I would check is the hose that goes inside the overflow. If it's not connected, or missing that will cause it. Also, make sure that the cap is staying on and sealing. If that's the problem you can buy a new cap with inner hose for about $15 from the dealer. I had to when I first got mine. Also, check the radiator cap. If the rubber is cracked and or deformed it isn't sealing and can cause the system to de-pressurize. A new one will run you about $5 at a parts store.
