Old 01-28-2008, 09:17 PM
wrexink's Avatar
wrexink wrexink is offline
Send a message via MSN to wrexink Send a message via Yahoo to wrexink
Cool My Garage Diorama Wip!!
Well Here are the walls and everything roughly. Sorry about the bad quality pics! I did as best as i could to touch them up. But the front part of the garage is going to be the shop part and the back is going to be the actual garage. It is 1:24 scale and is going to have garge doors and everything else you name it! The last pic is negative so you can see the pattern of the outer walls. Any questions just ask!
All the material is getting cut out with just a small X-Acto knife. so you gotta give me credit there. The rough edges you wont even see when i get the siding done on both the inside and the outside of the shop.
P.S. (Top Secret) there will be a working T.V. in the shop area mounted on the wall. Like a plasma Screen I will post pics soon!
My MySpace> www.Myspace.com/stuntit
Old 01-28-2008, 10:15 PM
Adam Baker Adam Baker is offline
Send a message via AIM to Adam Baker Send a message via MSN to Adam Baker Send a message via Yahoo to Adam Baker
Re: My Garage Diorama Wip!!
Looks good so far.
When you cut the foamcore, the best thing to do is use some kind of straight edge, and dont try cutting completely through in one pass. Make several slow passes, and it will make for much cleaner cuts.
Old 01-28-2008, 10:23 PM
drunken monkey's Avatar
Razor Sharp Twit
use a fresh blade.
if you've got a metal edge, a fresh blade should cut in a single pass.
AF's Guidelines
Read them.
Old 01-29-2008, 04:01 AM
09WNS/14BRK's Avatar
09WNS/14BRK 09WNS/14BRK is offline
looks good so far
Thanks 09WNS/14BRK
R.I.P Peter Brock
26-2-1945 - 08-09-2007
Old 01-29-2008, 07:04 AM
wrexink's Avatar
I do use a good blade and I dont it in one pass. I need a metal straight edge because my plastic one my X-Acto knife cuts right into. and You wont see the rough edges when I get the brick siding on and stuff thanks for all the comments! I would appriciate more!
Old 01-29-2008, 03:51 PM
wrexink's Avatar
Today I made all the cuts (Windows, Doors) Smoother and Started making the Display case for the front of the shop!
Old 01-30-2008, 08:32 PM
wrexink's Avatar
More progreess comming as soon as I get More pieces and Styrene sheets.
Old 01-31-2008, 02:07 AM
rod_k2's Avatar
rod_k2 rod_k2 is offline
Send a message via MSN to rod_k2
"Oh noez,it has more stickers than me! And a wing too!
Old 02-03-2008, 06:54 PM
wrexink's Avatar
Got more crappy pics. Sorry about them! Ill try to take better ones tomarow!
Got a bunch of trim and Stirene sheets and stuff.
Got the inside front wall done
Old 02-03-2008, 06:59 PM
freakray freakray is offline
AF Modelrater
I think things are looking good, but it's impossible to actually say with the quality of photos you post.
I implore you, get a better camera, please
AF User Guidelines
Old 02-03-2008, 08:35 PM
Razor Sharp Twit
small tip; if you give the walls some proper thickness, the end result will look better.
AF's Guidelines
Read them.
Old 02-22-2008, 05:01 PM
wrexink's Avatar
Exclamation Re: My Garage Diorama Wip!!
Got more progress pics finaly! I got these small garge parts from SMBC modeling. and you have NO idea how hard it is to make those little boxxes! Let me know what you think! More pics comming soon to!
Here is the work-bench put together and painted!
trash can is actaully a light semi-gloss grey it has some stickers on it to!
Here is the engine lift painted and assembeld!
Phones
Laptop. Hair isnt on it any more. lol
Stero
Small Boxes i made.
Old 02-22-2008, 05:48 PM
NSX Fan NSX Fan is offline
love the props
Old 02-23-2008, 02:29 AM
looks goo nice work
Thanks 09WNS/14BRK
R.I.P Peter Brock
Old 02-23-2008, 02:30 AM
CifeNet's Avatar
CifeNet CifeNet is offline
This is so cool! I love that Greddy!
-- CifeNet
