Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-28-2008, 06:56 PM
evildragon evildragon is offline
changing spark plugs
I wanted to learn how to do this myself, and while looking around the engine finally finding the spot, all i can think is, my god, how am I supposed to change the spark plugs on an LT1?
My one and only car!
1994 Chevy Caprice Classic LS
L99 Engine
Old 01-28-2008, 07:23 PM
96capricemgr 96capricemgr is offline
Re: changing spark plugs
It is a PITA. On some of them it helps to use an extension and wobble joint through the wheelwells. I can get them all from top though.
Really not something I can give detailed instructions on, more of a dive in and gitterdone sort of thing.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
Old 01-28-2008, 08:27 PM
Blue Bowtie's Avatar
Registered Offender
I have changed them all from the top. #2 and #4 are a little tough, and might be more easily accessed from the bottom or wheel opening.
Changing the spark plug wires, however, is a different thing entirely. Plan on several hours just to route them the same way the originals were installed.
Old 01-29-2008, 02:39 AM
16th hippy 16th hippy is offline
this is like pulling a transmission out of an S-10. if you got the money, pay someone to do it. it is a real pita. best of luck.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 01-29-2008, 11:58 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
On my Caprice, the driver's side is not that bad. The passenger's side is another story. I agree on going under the fender... and removing the tire. I'll keep the jack under the car to lower and raise it as needed.
I use a long 3/8 extension, flex head ratchet, other extensions, a 3/8 swivel in various combinations. An old spark plug boot is good to get them started.
It takes me around 3 hours and I run out of curse words after the first hour and make up new ones.
Bob
Old 01-29-2008, 06:40 PM
j cAT j cAT is offline
Bob
i agree to remove tire and get to some from under. because plugs last a long time i do the plug change at tire rotation/grease inspect front end maintenance time rather than special r/r for plugs. saves your back also.......you can get a good look at wire condition better when it is done this way......
