please help
please help if anyone knows how to program a keyless
remote for a 2005 pontiac grand am i do have one left did buy 2 more and the last two remotes needs to be programmed.if anyone can help it's much appreciated thanks a bunch:}:}:}:}:}:}:}:}:}:}:}:}:}:}:} |
Re: please help
Welcome to AF.
It'll need programed by the stealership.
1999 Grand Am SS 3.4 OHV
Re: please help
Yep, stealership
Transmitter Programming Important All transmitters that are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly. The scan tool must stay connected until all of the transmitters are programmed. Install a scan tool. Turn ON the ignition with the engine OFF. With the scan tool, select Body, go to Remote Function Actuation. Select Special Functions. Select Program Key Fobs. Select the number of key fobs to be programmed. Press and hold the LOCK and the UNLOCK buttons simultaneously on the first transmitter for approximately 15 seconds. The power locks should cycle to confirm programming of the first fob is complete. If you are programming more than one transmitter, repeat the previous step to program up to 4 transmitters. Remove the scan tool. Exit the vehicle. Attempt to lock/unlock the doors to verify the programming. Operate the transmitter functions in order to verify correct system operation. |
Re: please help
That's kinda usless headnsouth, since most folks dont have a Tech II scnner.
Re: please help
Re: please help
It usualy doesnt cost much if anything to have the dealer program them, I do know that. Those Tech scan tools are a little pricey, I picked up a used one a year ago for around $2k.
Re: please help
Yea, I would love one of those but ka-ching!
I use an auto-tap for my autos which works fine for what i do.
Re: please help
thanks for your help guys i thought i can do it my self 'coz the stealership
where i am charge $65 per half hour,agai many thanks Quote:
Re: please help
Autotap is a great program I know a lot of people use it find it easy and straight forward. Quote:
Sorry we couldnt help , and Good Luck.
