Old 01-28-2008, 05:47 PM
buff6116 buff6116 is offline
Question Poor Mpg
I have a 98 GT with 155,000 i get about 20-24 on the highway any ideas? i have had it for a month and put on 2,500 miles. It is stock other than opening the factory air box alittle. My 98 bonnie got 27-33 its the same motor and tranny set up and that had 280,000 any ideas?
Old 01-28-2008, 07:21 PM
Burtnette Burtnette is offline
Re: Poor Mpg
Winter....
CURRENT:
1997 Grand Prix GTP
Mods:
U-bend/Res Delete
3.4"
MSD 8.5mm
TR6s
ZZP 1.0 PCM
72mm TB w/ TB spacer
WizAired CAI
3" DP w/ Borla Pro XS mufflers
OLD:
1995 Dodge Stealth
Old 01-28-2008, 08:10 PM
eippermx's Avatar
eippermx eippermx is offline
Re: Poor Mpg
Originally Posted by Burtnette
Winter....
oxygenated fuel...Gotta love it, er -- hate it.
mark
mark
Love my Pontiacs!
'04 GP GT1
'02 Bonneville
'98 GTP - 2 dr
'98 GTP - 4 dr
'99 GP "Flaming Tomato" GT
Old 01-28-2008, 09:19 PM
Re: Poor Mpg
I use the same fuel in both cars tho and i drove the bonnie in many of winters and never got that poor MPG i was wondering if maybe it was the mass air flow senser or some thing dumb like that.
Old 01-28-2008, 10:47 PM
Re: Poor Mpg
Seems like they did something they did to the gas this year has a very bad reaction to our Grand Prixs because everyone with a Grand Prix has a lot worse gas milage right around now.
CURRENT:
1997 Grand Prix GTP
Mods:
U-bend/Res Delete
3.4"
MSD 8.5mm
TR6s
ZZP 1.0 PCM
WizAired CAI
OLD:
1995 Dodge Stealth
Old 01-29-2008, 01:48 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Poor Mpg
Mine is doing juct fine. All things considered Im getting 22mpg combined highway and city (even including warm up time).
Buff6116 you may want to check out your tire pressures and make sure that OD is working.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 01-29-2008, 06:53 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Poor Mpg
20-24 mpg on the highway is low even for winter fuel. Starting with the basics, has it ever been tuned up (plugs, wires, fuel filter, PCV)? If so, were quality parts used? Any CEL on, and if so, have you had it scanned? Have you checked fuel pressure (should be 48-55 psi, key on/engine off)?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-29-2008, 01:28 PM
Re: Poor Mpg
Here is what i know i bought from a guy that worked at a GM dealer. He just put in a new upper intake about 10,000-15,000 ago the plugs look good they are AC delcos the wires look fine. It also has a new fuel regulator. I put it on the scaner right after i bought it and there was one code for the ABS mod thats bad and nothing els not even a miss fire. I put in a new air filter in it to. Tire pressure is good with this frozen MN weather i do keep up with air in tires when needed. Yes it goes in to OD. With letting it worm up and driving a few miles i am geting 11 mpg. Fuel filter is on my to do list i will check the fuel pressure next time i am home from college to see how that is. I still have my Bonnie but that died do to a short in the main harness is it worth taking the throttle body and every thing off that and puting on the GT?
Thank you guys for all the ideas so far!!!
Old 01-30-2008, 01:25 AM
mFLiP91 mFLiP91 is offline
Re: Poor Mpg
I would love to get 20mpg, I'm getting 13.8
1997 Grand Prix GTP 118000 miles
Old 01-30-2008, 06:55 AM
richtazz's Avatar
Re: Poor Mpg
I get 20-22 around town in my 99 GT. I'm not a leadfoot, but I'm no bluehair on the gas either. I get 32-33 on the highway if I keep it under 75. If I get above that, it starts dropping significantly. Unexplained bad mileage usually goes back to three things.
1. Bad/worn tune-up/emission components (plugs, wires, air filter, PCV, o2 sensors, MAF sensor, etc...)
2. Exhaust blockages (bad converter, resonator, muffler)
3. Fuel pressure issues (leaking pressure regulator, weak pump, clogged filter)
Old 01-30-2008, 03:49 PM
Re: Poor Mpg
Come spring when its not -20 like it is now i think i am going to get an off road down pipe and a cone air filter set up. Should i get rid of the resonator well i am down there or no big deal. This 10-12 MPG Winter City stuff sucks but i still love the car.
Thanks richtazz
Old 01-30-2008, 05:45 PM
Re: Poor Mpg
I removed my resonator (stock one had a hole in it) and the only thing I noticed was a nicer sound. I'm not really an exhaust head at all though but it doesn't seem like it hurts the car in anyway.
CURRENT:
1997 Grand Prix GTP
Mods:
U-bend/Res Delete
3.4"
MSD 8.5mm
TR6s
ZZP 1.0 PCM
WizAired CAI
OLD:
1995 Dodge Stealth
