bulb plug melting
Like it says, I've replaced two plugs in the last three weeks. They look burnt like they were heated with a torch. It's an 02'.
Re: bulb plug melting
Are they oem?
2002 LT Trailblazer 4x4 One of the first of this kind on the road 2003 3500 LT Silverado 4x4 ext cab 2006 Heritage Softail HD FLSTI |
First one was oem, then an aftermarket replacment, both did the same thing. They burn up and I lose the use of the headlight. Before this happened I was replacing bulbs at an alarming rate.
Check the ground side of the bulb sockets, this is a fairly common problem with AM bulbs, NAPA makes a heavy duty repair connector, this must be soldered into the oe harness.
You would'nt know the part# would you? |
They are packaged in their electrical parts turnstile.
It's not that simple around here. NL.Canada that is.
