Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 01-28-2008, 02:38 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
How would you tack a bolt head in place to an aluminum seat rail?
Installing the ultrasheld in the panoz using the Hardbar seat mounts I had for the corvette. Had to drill new holes to meet up w/ the panoz chassis and the rear bolt heads are not accessible with the seat in. The bolts go down through the frame and use a lock nut under the car.
So.... I need to bolt heads tacked in place so I can tighten the nut on them. The seat rails are aluminum. A local body shop near me didn't have the rigth welding rod and the weld he tried popped right off.
I need this back bolt to be locked in place before I put the seat in:
I got some of this Permatex metal epoxy:
Would it work? Or shold I take it all to a shop and have them weld 2 strips of aluminum plate to either side of the hole so when the bolt head is in place it cannot turn?
Thoughts? I figure if a Lotus Elise's chassis is all bonded/glued together that the right stuff shold do the trick, no?
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 01-29-2008, 01:19 AM
Cobra4B's Avatar
Re: How would you tack a bolt head in place to an aluminum seat rail?
Epoxy worked like a charm.
Brian B.
