Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-27-2008, 09:13 PM
demaleon demaleon is offline
98 Cvpi
running rough like a mis, replace spark plugs and still.
check eng ligth off no codes. also blower motor switch
only works on fan high speed.need help!
thanks
Old 01-29-2008, 06:07 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 98 Cvpi
Blower resistor will cure the fan problem. An engine miss will not necessarily set the check engine light. You need to have a scanner that will read each cylinder for an engine miss. If you have a scanner that has the mode$06 data, it will pinpoint the exact cylinder that has been missing. Look closely at the coil boots to see if there is indication of a spark burning through the rubber boot. You can also unplug each injector or coil one at a time until there is no change in the running of the engine. That is the cylinder that has tha problem.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
