Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-27-2008, 06:21 PM
mike561 mike561 is offline
slight starting issue
This started happeneing recently and only when the engine is cold, ill go to start the car, it starts up fine, then begins to putter and want to die out, ill have to keep the gas pressed a bit and rev it a few times for it to stay on steady. i dont think the idle is set too low cause after a few minutes its fine
2006 Chevy Cobalt LS
Old 01-27-2008, 08:48 PM
Blue Bowtie's Avatar
Registered Offender
Re: slight starting issue
If the engine is still carbureted, as it should have been when new, there is a high idle cam which is supposed to be operated by the choke plate linkage. The choke pull off will also affect it. The high idle speeds are independently adjusted on the high idle cam, so the hot curb idle setting has nothing to do with that.
Make sure the choke is closing properly when the engine is cold, and that the high idle cam is following along. Make sure the choke pull off is adjusted properly, and that the choke opens properly when warmed. Once the engine is fully warmed, you can check/set the high idle speed.
The fast idle cam is identified by the yellow arrow.
Old 01-27-2008, 10:47 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Mine did that too, until I was performing a routine maintenance on it and discovered the idle air bleed wasn't tuned properly. Using a dwell meter, it was determined that at idle the idle bleeds (and M/C solenoid since they're intertwined) were pulling about 20% duty cycle (15 degrees dwell on 6-cyl scale). 50% +/- 5% is operating range. On a 6-cyl dwell scale this will be 30 degrees, +/-3 degrees. Adjusting it removed the problem.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-28-2008, 12:26 AM
Ok ill take a look at that in my class, they have all the tools and whatnot to do those adjustments. theres always been something falkey about this carb when i got the car, it seems everything on it was mis-adjusted or something.
Old 01-29-2008, 06:50 PM
j cAT j cAT is offline
ok now i'll add my 2 cents worth i believe your electric choke stove needs replacing this over time looses it's spring movement and after the engine starts does not have suffcient spring force to keep the throttle plate and hi speed cam in the proper position. do not adjust anything if this is the case because to get it perfect it is a PITA.......after new stove is installed check for throttle plate pull off gap mine was .172 used drill bit or .157
Old 01-30-2008, 06:53 PM
I just remembered be very careful when using carb cleaner. if any cleaner gets into the choke pull off /or secondary pull off it will damage rubber diaphram and this will be baddddd......
Old 01-30-2008, 09:24 PM
last night i noticed the little blue wire was disconnected from the round thing on the left side of the carb, so im sure this was contributing to it, dunno how that happened
Old 01-30-2008, 10:20 PM
Registered Offender
The "round thing" should be on the RIGHT side of the carb (passenger side). If that's the case, it's the choke heater. If that was disconnected, the choke may not have been opening as it should. If someone compensated by rotating the choke thermostat, you may need to readjust. If it wasn't moved, The choke pull-off may not be adjusted properly.
Old 01-30-2008, 11:45 PM
yeah it was on the pass. side, it may have accidently gotten disconnected, i was doing some work under there the past few days
Old 01-31-2008, 06:23 PM
because the choke gets hot the electrical connector gets damaged over time, and i had to replace with another connector.
