Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 01-27-2008, 02:28 PM
MamuSpral MamuSpral is offline
1999 Protege Gasoline smell in oil
Hallo
I bought a 99 Protege for CA$1K as a spare car with 213kms on it. I am noticing a strong gasoline odour when I pulled the dipstick and drained the oil. If anyone has an idea what could be causing this please reply to my post. I can also smell this odour in the air around the car when it is running so it is probably coming from the exhaust also. The car starts fine and everything though. Only thing I have noticed is that it idles a bit high when in neutral or park but not sure if this is normal.
Thanks
Old 01-28-2008, 03:45 AM
Flash75 Flash75 is offline
AF - Advisor
Re: 1999 Protege Gasoline smell in oil
Sounds like the fuel system is running too rich. Check the air cleaner, it may be clogged. Remove a spark plug and look for sooty or wet electrodes. Is the check engine light on? Check for vacuum leaks in the intake system, a vacuum leak could cause the engine to run too rich.
Clifton
Old 01-28-2008, 02:51 PM
Doug Tatham Doug Tatham is offline
Either check or have your compression checked. Bad rings could allow exhaust to blow past the pistons into the oil pan. It would then go throughout engine. Follow the advise above by Flash75 as well.
Old 01-30-2008, 10:31 AM
Thumbs up Re: 1999 Protege Gasoline smell in oil
Thanks . I have found a leak in that big hose (forgive my terminology) that goes from the air box to the throttle body. I will try to seal it and see what happens. My check engine light is currently on but I will try disconnecting the battery for a ˝ hour after I seal the hose and see if comes back on. I do not currently have and OBD2 scanner but might get one if the problem persists. I will post an update once I have done this.
Thanks again.
Old 01-30-2008, 03:35 PM
I don't think disconnecting the battery will clear the OBDII. Most autoparts stores will read and clear a CEL for you.
Old 02-10-2008, 06:28 PM
Thanks Dough and Flash for your help.. Sealing that leak and disconnecting the battery seems to have resolved the check engine light issue... I will have to watch it over time to see if the gas smell in the oil goes away or look into plugs/compression as suggested
Old 02-10-2008, 06:29 PM
Sorry Doug I got your name wrong
