Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 01-27-2008, 03:27 PM
joshnumber21 joshnumber21 is offline
Banned
No Heat IN MICHIGAN!!!
For a few weeks, it would take a while to kick on. (CRT screen had to finish the diagnostic check at startup or it wouldn't work). Sometimes when I would push the window button in the UP direction, the heat would kick on. Sometimes when I would slam the door hard, it would come on. Now-nothing. There is a little heat coming from the windshield/defroster vents, but it could be incidental/coming from the engine compartment. No defroster, no vent heat, no heater, no bi-level. Relay?
I'm sorry I post so many problems, but this doggone car is just one thing after another right now. Rolled over 228k yesterday.
Old 01-27-2008, 06:48 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: No Heat IN MICHIGAN!!!
Turn the controller to High Fan speed, to see if the blower will come on. If not, check voltage at the fan terminal. If you have 12v on the terminal, tap the blower motor firmly, with a hammer to see if it will start. If not, suspect the blower control module. In addition, check all ground terminals!
Old 01-29-2008, 05:33 PM
Banned
Well, tapped the blower motor with a hammer and BINGO. It came on. If I switch it off high setting, it shuts off. Sounds like the blower motor, am I right?
Old 01-29-2008, 06:31 PM
HotZ28's Avatar
AF Moderator Elite
YES, I think you have found the problem! Replace the blower motor ASAP, before it damages the blower control module!
Old 02-19-2008, 05:13 PM
Banned
FINALLY replaced the blower motor today. Kinda funny that the part says "Siemens VDO" all over it. Thats where I work, but no discount?
Good as new!!! Thanks for your advice everyone!!
