Too fast idle
Hi all. Have a 93 DD 3.9l. It idels too high 1000rpm's at park and warmup. Have replaced plugs wires pcv..How do i adjust this Fast idle cam to lower the idle RPM?. If im NOT supposed to do that what do I do?
Thanks |
Re: Too fast idle
A slightly higher idle speed is normal after a cold start...1000 to 1200 rpms is the typical range. Once the ECM senses a rising engine temperature, it will gradually reduce throttle to normal idle speed.
If the truck is ALWAYS starting up idling high regardless of temperature then I would check your engine temp sensor.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
