Old 01-27-2008, 01:43 AM
nlohman0717 nlohman0717 is offline
4x4 problems... again
ok...heres the problem...originally my 4wd was not working at all....the lights would blink and it would not engage the front tires...I was having all kinds of problems...I found out one of my vacuum lines had a hole in it...i replaced the line and everything was working fine....until the other day...I turned my car on and none of the lights (2hi, 4hi, or 4lo) were lit...about 20 minutes after driving my 2hi light finally came on, but I was unable to change to 4wd...I would press the 4wd button, but the 2hi light stayed lit....no clue whats going on
Old 01-27-2008, 09:17 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 4x4 problems... again
Always give year and make and engine and mileage.
And what transfer case you have.
If no lights on a key on bulb check.
Look over wiring and fuses and power feeds first.
MT
MT
Old 01-27-2008, 12:06 PM
Sorry, I got a little ahead of myself...Its a 95 blazer, 4.3, with 143,000 miles on it. I have no clue what transfer case I have, and I checked out the wires on the back of the 4wd switches and everything seems fine.
Old 01-27-2008, 04:35 PM
MT-2500's Avatar
AF - Advisor
There is a ID tag on the back of it.
But should be a 233.
On that one key on you can ground pin 13 on diagnostic connecter and get transfer case codes.
Check all wiring and plugin and fuses and if you can get a code post back code no.
Also Muddog has a how to on it that may help or search other post on here.
http://www.automotiveforums.com/vbul...d.php?t=572914
MT
