Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-26-2008, 07:35 PM
tegseal tegseal is offline
Ran dry of fuel need help restarting
My dodge ram 3500 cummins turbo diesel ran dry and won't start. I have refilled the canister to the filter and of course put fuel into the tank. Any suggestions on what to try next? Need info asap. Email [email protected]
Old 01-29-2008, 04:15 AM
fanworks fanworks is offline
Re: Ran dry of fuel need help restarting
Leave your gas cap off and crank the engine for a while. Let it rest, then crank again for a while, let it rest, and repeat. It'll take a bit of time to get all the air back out of the system.
CB Channel 17
Space Ghost
'1992 Dodge W-250 Club Cab Long Bed V8 5.9l 4spd H.D Auto 4x4 4.10 Gears
'1974 KIT 11' Kamper
'1987 Custom Built Pullman Mini Camper (The Pullman Mini Camper Project)
'2004 Bi-Mart 1000lbs Cargo Trailer (Chuck wagon)
Old 01-29-2008, 08:37 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Loosen the injector fittings on #1, #3, #4 & #5 injectors. They take a 19mm or 3/4" open end wrench.
With the throttle to the floor, crank the engine over a few seconds then check the fittings for wet fuel and tighten the wet ones until the motor starts kicking and tries to start then tighten all the loose ones.
What year Dodge is your truck? The 1998.5 to 2002 24 valve motors have a troublesome lift pump design but is easily fixed.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 06-13-2008, 12:46 PM
rwilber rwilber is offline
just replaced the lift pump on a 1998.5 diesel...manual says to do it from below by removing starter
its easier to do it from the top...remove the fuel filter and you have easy access to the lift pump...cummings doesn't sell the lift pump any more but you can get a carter after maket oem for abt $160 lift pump came with the
seal washers 2 per bango bolt...you'll need 4 more if you remove the fuel filter..
