Old 02-22-2003, 09:28 AM
Touge180 Touge180 is offline
This sucks (long)
okay so i go out to my car this morning to go and put gas in it so i turn the key and wait for the check engine light to go off so it does and the i start the car and wiat for the oil light to go off it does but it takes longer than it usualy(sp) does so i pop the hood and check the oil and what do i see not a DAMN DROP OF OIL IS IN THEIR SO IM LIKE HOLY SHIT.
So thats why my car studders when i put it to the floor god knows how long theres been no oil.So i went out and got some oil put it in and drove it now when i floor it it fine.
So what can cuse the oil to disappear my dumb stepdad says i need a rebuild but i did notice some oil aroud the oil pan??????
Old 02-22-2003, 09:38 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: This sucks (long)
Hes right Yeh also check the oil pan maybe u need to change it.
Old 02-22-2003, 03:08 PM
Hatchin Hatchin is offline
Send a message via ICQ to Hatchin Send a message via AIM to Hatchin Send a message via Yahoo to Hatchin
Ridin without any oil!!!
Your lucky that you didn't cause a lot more damage
CRX Si
Old 02-22-2003, 04:20 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Oil pan gasket and hope that you didn't ruin a rod bearing.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 02-22-2003, 06:17 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Could be burning oil too, better start checking it every couple days now or you'll burn it up....either way it sounds like time to rebuild the motor...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 02-24-2003, 09:27 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Yo Dude...I burn about a quart every 1200 miles...it is a good habit to check it EVERY time you fill up the tank...it will burn more when you ride it harder too... Look out the rear window when you are up there in the 5 - 6K range...do you see black smoke? It is easier to see at night, when there are peeps behind u with lights on...if you do, that is probably blow-by smoke, indicating worn out rings (burning oil in the combustion chamber)
if you see blue smoke at start up (cold engine) that indicates worn out valve seals..the oil leaks down the valves from the head when the car isn't running...they sit on top of the piston and burn when the car starts up. It is possible to have either of both conditions...blow-by will use oil more quickly..
My GF's car has an oil leak that leaves a 2" diameter puddle overnight, and it still took over 6 months to leak 1 quart of tranny fluid, so unless you see a big-ass puddle under your most common parking area, the leaking around the pan (which is common) is probably not the primary loss of oil.
My car has 208K miles on it and I noticed it burning oil about 175K...I decided to buy a ZC and rebuild it instead of rebuilding the d15b2...I just need to find good weather and/or a garage now to swap that bad boy in...
Sorry my reply was so long..but buying oil at $1 per quart is a lot cheaper than a rebuilt or swapped motor...I would recommend that you start saving some $$ and swap in something else when you are ready.. for now..keep driving it and check the oil often.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 02-24-2003, 10:06 AM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
Check your oil pan bolts, I tightened mine the other day, most of them I could have taken out by hand.
Old 02-24-2003, 10:07 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Hehe, my old 73MG had a blown headgasket, I had to add a quart once a week. :hehe: good times I had in that thing though.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 02-24-2003, 02:12 PM
sastanley's Avatar
AF Premium User
LOL - my '85 Civic was pretty bad..Every time I filled up the gas tank, I had to put in a quart of oil...I just bought the cheap stuff by the case - I had massive worn seals on that (I used to smoke out the neighborhood in the AM) and had blow-by issues too. I ended up trading that car in on this one, and the dealer "gave" me $300 for it...Honestly, I doubt I could have sold it for that much..it had other issues too
-Shawn
Old 02-24-2003, 02:18 PM
jam4484 jam4484 is offline
Send a message via AIM to jam4484
As Sastanley said u need to watch out for burnin oil and u don't wanna throw a bearing like i did in my accord. Just watch your oil from now on and then decide what u wanna do.
1989 Crx Si
-Aem cold air intake
-thermal cat back
-test pipe(makes exhaust sound really bad)
-Skunk2 short shifter and knob
-Hx wheels
-Tenzo front and rear strut bars
-parts waiting to go on- nuespeed header
-waiting to be built-my spare a6 block, with y8 head, 93 valve cover, z6 intake manifold, integra tb....
Old 02-25-2003, 01:35 PM
turbcivic's Avatar
We just did an engine swap today at work on an accord that threw two rods. Two holes on the front of the block, cyl #2&3 and one out the back of cyl #2.
